unable to load ios on 2821
I have a router and im tring to load image from rommon mode but i didnt. i tried a lot and various images but still its not i will provide you the error in below
rommon 5 > xmodem flash:/c2800nm-ipbasek9-mz.151-2.T1.bin
Do not start the sending program yet...
program load complete, entry point: 0x8000f000, size: 0xc940
         File size           Checksum   File name
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file flash:/c2800nm-ipbasek9-mz.151-2.T1.bin ...
Format: All system sectors written. OK...
Format: Operation completed successfully.
Format of flash: complete
open(): Open Error = -36
create a file failed...err code = -1
rommon 6 >
could you please update me with the exact problem and how to resolve this
thanks and regards
Lakshminarayana
5 Replies 5
Tim Smith
Enthusiast
Enthusiast
Hey mate...
Much better way to do this is with TFTP.
Especially with the size of IOS images these days.
Give this one a go.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Cheers,
Tim.
Nagaraja Thanthry
Please try the following:
xmodem -r "image name"
or
xmodem -r
This will load the image to the RAM and will boot the router. Then you can
perform regular TFTP process.
https://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note0918
6a008015bfac.shtml
If it is possible, you can also try TFTPdnld process.
a008015bf9e.shtml
If nothing works, if you have a spare router that takes the flash card, put
the card in that router, copy the image through normal TFTP process and then
put the flash card back in the router is question.
Hope this helps.
NT
Dear Nagaraj
Thanks for your replay and its more helpfull to me. but im  try with xmodem -c and fileneme its working now i can load the image. but in this process i got one more problem.
if you konw could you please tell me.
i.e. if i tring to load though tftpdnld its showing pre-configured ip address and tftp file name. im tring to download that one but its belongs to 2851 image file name. so im tring to change with set commands. but i didnt.
so my question is how to change the ip settings  in cisco 2821 router on rommon mode
see the procedure on which also works for most cisco device:
rommon's SET shows you the current values.
to change them, write
variable-name=vlaue
No spaces before or after the = .
Example from the URL above:
          rommon 16 > IP_ADDRESS=171.68.171.0
     rommon 17 >
IP_SUBNET_MASK=255.255.254.0
     rommon 18 >
DEFAULT_GATEWAY=171.68.170.3
     rommon 19 >
TFTP_SERVER=171.69.1.129
     rommon 20 >
TFTP_FILE=c2600-is-mz.113-2.0.3.Q
     rommon 21 > tftpdnld
No, you cannt ping the device, it's just used for tftp .
If tftp-server and device are on the same (V)-LAN, you may set DEFAULT_GATEWAY to the ip-address of the TFTP_SERVER.
Be sure only to give the switch the image;
not the .tar file with the webby-devices-management. You can load this later when IOS is running
by "archive tar /xtract URL flash: "
Hope this help's,
Juergen.
Leo Laohoo
VIP Community Legend VIP Community Legend
Got another option for you ...
Your router has a CF slot.  Put the IOS into a CF and replace it.
Recognize Your Peers
