Cisco Community Designated VIP Class of 2020
1061
Contributor
Unable to ping other side of DMVPN Tunnel
I am doing a lab and the Tunnel is UP/UP, however I can't ping the other end of the tunnel. Here are my configs.
Hub Rt:
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec profile cisco
set security-association lifetime seconds 120
set transform-set strong
interface Tunnel0
no ip redirects
ip mtu 1440
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 1
no ip split-horizon eigrp 90
no ip next-hop-self eigrp 90
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile cisco
Spoke Rt.
hash md5
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 192.168.1.1 209.168.202.225
ip nhrp map multicast 209.168.202.225
ip nhrp nhs 192.168.1.1
tunnel key 0
5 REPLIES 5
VIP Mentor
Re: Unable to ping other side of DMVPN Tunnel
the partial configs look ok. Do you have static routes in place, and EIGRP advertising the tunnels and any possible local networks ?
Hub Rt:
hash md5
interface Tunnel0
no ip redirects
ip mtu 1440
tunnel key 0
interface FastEthernet0/0
ip address 209.168.202.225 255.255.255.0
interface FastEthernet0/1
ip address 1.1.1.1 255.255.255.0
router eigrp 90
network 1.1.1.0 0.0.0.255
network 192.168.1.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 209.168.202.226
Spoke Rt.
hash md5
interface Tunnel0
no ip redirects
ip mtu 1440
tunnel key 0
ip address 209.168.202.226 255.255.255.0
ip address 2.2.2.1 255.255.255.0
router eigrp 90
network 2.2.2.0 0.0.0.255
network 192.168.1.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 209.168.202.225
Contributor
I re-did everything over pretty much exactly the same but I believe I was pointing to the wrong physically interface at first so everything works now. Yes I am using EIGRP.
On another related note, I am seeing very different configurations for configuring other spoke routers to be added to a DMVPN network. If I want to add another spoke router to this hub DMVPN router, do I create an additional tunnel the same as I did on this hub and spoke routers? Any information would be helpful.
VIP Mentor
yes, basically any new spoke would have a similar config except for (obviously) the IP addresses. Keep in mind there are three different DMVPN phases, that might explain why you see different configurations...
Beginner
Hello!
Without IPSEC profile on Tunnel interface, ping succesful?
Contributor
no I still can't. What else do you think I should check?
Content for Community-Ad
