Understanding cable diagnostics output
ja raju
Hi guys,
I have this output from a cable diagnostic test that I did. How do I pinpoint at which end the pair is open? Is it at the closet end or user end?
show cable-diagnostics tdr int f0/39
TDR test last run on: January 27 10:45:54
Interface Speed Local pair Pair length        Remote pair Pair status
Fa0/39    auto  Pair A     6    +/- 1  meters N/A         Open                <===
                Pair B     39   +/- 1  meters N/A         Open                <===
                Pair C     N/A                N/A         Not Supported
                Pair D     N/A                N/A         Not Supported
Thanks in advance.
You mean at both locations?
Look at the output of the "sh cable test tdr".
Pair A is detected to be 6 metres away from the switch port (+/- 1 metre error).  Pair B is detected to be 39 metresaway from the switch port (+/- 1 metre error).
Pair C and Pair D is not tested because your interface is a fastethernet interface.
10 Replies 10
Leo Laohoo
"open" means the far end has nothing connected to it.
"normal" means good and something is connected to the far end.
"short" means short circuit.
"Impedance Mismatched" means a Cat5 cable has been joined with a Cat6 cable.
Don't forget to rate our useful posts.  Thanks.
How do I know how far from the switch is it open/broken?
In your output, under "Pair" is the length.  Do you see that you have two disparate distance?  It means you have a break somewhere.
So there's no way to see exactly where it's broken?
Thanks anyway...
6 and 39 metres from the switch's port.  +1/-1 metre error.
I take that as a yes
Thanks.
jatinsingh19093
Hi Every one
Interface Speed Local pair Cable length Remote channel Status
Gi3/45 1Gbps 1-2 71 +/-1m Unknown Terminated
3-6 74 +/-1m Unknown Terminated
4-5 238 +/-1m Unknown Terminated
7-8 0 m Unknown Terminated
why it states as terminated
@jatinsingh19093 wrote:
Terminated
This TDR result is taken from a Catalyst 4500 because it uses the word "Terminated" instead of "Normal".
Uhhhhh ... 238 metres?
