UNHANDLED ROMMON EXCEPTION on WS-C4948-10GE
weichenb2
While attempting to load a new IOS (cat4500-entservicesk9-mz.150-2.SG2) onto a 4948. I put new IOS on the 4948, deleted the old IOS, and reloaded it; ensuring that IOS was to be loaded from flash. That is went I noticed the UNHANDLED EXCEPTION and the 4948 continually reboots. I, then, changed it to have it boot from TFTP (same IOS) and same problem. Does any have an idea what might be going on?
Your ROMMON version is 12.2(31r)SGA, which is affected by DDTS CSCsw91043. This Bug is related to Rommon Code and you are required to upgrade it to 12.2(31r)SGA4.
Please find the link below for instructions:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/release/note/OL_9592.html#wp305422
New ROMMON file can be found at:
http://www.cisco.com/cisco/software/release.html?mdfid=279636820&release=12.2(31r)SGA4&relind=AVAILABLE&flowid=3589&softwareid=280805687&rellifecycle=&reltype=latest
Note that the above link is for 4948 10 Gig Ethernet switch.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
9 Replies 9
Arumugam Muthaiah
The switch might end up in a continuous reboot sequence if the boot variable is not set to the correct system image file and proper destination device. For example, the configuration register value of 0x2102 requires that a boot variable is specified by issuing the boot system flash configuration command
  • Issue the show bootvar command to check the current boot variable
  • Ensure that you specify the correct image with below boot sequence.
     Example:
     #boot system flash bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
  • Save the config
  • Check the boot variable again to make sure it is set properly so that the switch boots up the correct system file on the next reboot. Issue the show bootvar command in order to do this
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
The 4948 is in ROMMON now, so I do not this those commands will work.
Sorry for the late response. Please see below detail to recover from Rommon mode,
Issue the dir bootflash: command to list the files present in the bootflash, or issue the dir slot0: command to list the files present in the Compact Flash device.
Example:
rommon 1 >dir bootflash:
   File size                  Checksum      File name
   6516904 bytes (0x6370a8)   0x7b7edb21    cat4000-is-mz.121-11b.EW
   Total space = 61341696 bytes, Available = 54824664 bytes
rommon 2 >dir slot0:
   Total space = 128057344 bytes, Available = 121540312 bytes
Note:
The reason the switch reboots continuously is because the system image file name specified does not exist, but there is a valid file in the bootflash and slot0:. Also, the system image file name specified is case sensitive. If it is not specified correctly, it causes a continuous reboot
If the required system image file present in the bootflash:, you can issue the boot bootflash:<filename> command to boot the switch. Issue the boot slot0:<filename> command if you want to load the system from the file present in slot0:
Example:
rommon 2 >boot bootflash:cat4000-is-mz.121-11b.EW
Once the switch restore, Plesae check the previous steps which i shared already to avoid continuous reload
Refer:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
Aru
I entered the follwoing command.
boot bootflash:cat4500-entservicesk9-mz.150-2.SG2.bin
As you can see the file is in the flash.
rommon 2 >dir bootflash:
  19459812 bytes (0x128eee4)  0x2155b5b6    cat4500-entservicesk9-mz.150-2.SG2.bin
   Total space = 61341696 bytes, Available = 41881756 bytes
While rebooting, I see the following statement in the output, but continue to receive "UNHANDLED ROMMON EXCEPTION at PC=0453ab5c".
******** The system will autoboot now ********
config-register = 0xa441
Autobooting using the first file from bootflash.....
I have noticed that you have config-register set to a value 0xa441 (is it an error or a leftover of previous troubleshooting? I did not see such value being used before). Could you try setting it to default 0x2102, please? Command is "confreg 0x2102" in ROMMON or "configi-reg 0x2102" in IOS config mode.
If it still fails, please share the console logs showing complete boot sequence from boot start to the crash following by reset to ROMMON.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
rommon 2 >set
PS1=rommon ! >
RommonVer=12.2(31r)SGA
CV=bootflash:cat4000-i5s-mz.122-25.EWA10.bin
DiagMonitorAction=Normal
ConsecPostPassedCnt=14
IpAddr=192.168.1.2
Netmask=255.255.255.0
Broadcast=192.168.1.255
Gateway=192.168.1.10
TftpServer=192.168.1.10
ConfigReg=0xa002
BootedFileName=bootflash:cat4000-ios-promupgrade-122_25r_EWA
rommon 3 >confreg 0x2102
usage: confreg
Here my attempt to use boot bootflash: command.
rommon 5 >boot bootflash:cat4500-entservicesk9-mz.150-2.SG2.bin
Rommon reg: 0x00004180
k2diags version 5.7
prod: WS-C4948-10GE  part: 73-9344-09  serial: FOX112905U3
Power-on-self-test for Module 1:  WS-C4948-10GE
Port/Test Status: (. = Pass, F = Fail, U = Untested)
Cpu Subsystem Tests ...
seeprom: . temperature_sensor: .
Port Traffic: L2 Serdes Loopback ...
0: .  1: .  2: .  3: .  4: .  5: .  6: .  7: .  8: .  9: . 10: . 11: .
12: . 13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: .
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: .
36: . 37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: .
62: . 63: .
Port Traffic: L2 Asic Loopback ...
Vector=00000100 MSR=02029230 LR=0453ab24
MCSR=00000000
CISR0=00000000 CISR1=40000000
DDR_ERR_DETECT=00000000
* Welcome to Rom Monitor for WS-C4948-10GE System.       *
* Copyright (c) 2003-2006 by Cisco Systems, Inc.         *
* All rights reserved.                                   *
Rom Monitor Program Version 12.2(31r)SGA
Supervisor: WS-C4948-10GE  Chassis: WS-C4948
Hardware Revisions - Board: 8.5 CPLD Gill: 20
MAC Address  : 00-1d-45-66-bb-ff
IP Address   : 192.168.1.2
Netmask      : 255.255.255.0
Gateway      : 192.168.1.10
TftpServer   : 192.168.1.10
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Autoboot cancelled......... please wait!!!
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Kibimbwa.r
Hello Team,
Please, anybody can help me ?
I have the same issue, my WS-C4948-10GE can load ios normaly just rommon mode.
rommon 5 >set
 PS1=rommon ! >
 CV=bootflash:cat4000-i5s-mz.122-25.EWA7.bin
 ConfigReg=0x2101
 ConsecPostPassedCnt=62
 BOOT=
 IpAddr=172.26.10.134
 Netmask=255.255.255.192
 Broadcast=172.26.10.191
 Gateway=172.26.10.129
 TftpServer=172.26.10.167
 BootedFileName=bootflash:cat4500-entservicesk9-mz.150-2.SG11.bin
rommon 6 >
I would like to know, how I can upgrade cat4500-ios-promupgrade-122_31r_SGA7 on ROMMON MODE because he can work with this IOS cat4500-entservicesk9-mz.150-2.SG11.bin
I'm in ROMMON MODE now !!!
HELP HELP HELP HELP
