Unsupported Baud settings on a 2960
Andrew Escher
I seem to have managed to set a 2960 to 230400 baud in the boot loader. Is there anyway to reset the variables in the boot loader? Maybe a set of pins to short? I can't access the console port reguardless of what I set the rate too. I've tried both the USB console cable and a USB to serial. Is there anything I can do short of an RMA?
6 Replies 6
fb_webuser
Level 6
Level 6
It is little tricky, you can use aux port with xmodem commands and configure speed for the baud rate you need on line con 0 from there.....
Posted by WebUser Neeraj Jagga from Cisco Support Community App
To my knowledge the 2960 doesn't have an AUX port. Great ideal though. I've got a usb console port, serial console, management and the USB port.
Can you telnet/SSH into the appliance?
Ryan Gadwood
Andrew,
You may have to do a password recovery procedure on this switch. See link below. This should bypass your startup config so you can set to your normal 9600 and get into the switch. Hope this helps.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Ryan
andrkvcisco
after command
set BAUD 23400
console speed set to ~17000 !
BUG
https://supportforums.cisco.com/thread/2238189?tstart=0
Ajith Kumar
Kindly help me same problem iam having C2960S.
