11-24-2015 08:36 AM - edited 03-08-2019 02:49 AM
We have a network communication failure at a industrial site, that uses some tcp and udp communication. To monitor I'm using tcpdump to collect the packets from one port to a mirrored port at the same switch.
Looking for the root causes, we've found some unexpected packets coming from a different IP source and destination from the host that were monitoring.
I know it would be some spanning tree issues, as I saw at:
https://supportforums.cisco.com/discussion/10724911/unsuspected-traffic-while-sniffing
Something at our topology change would causes the MAC address tables to flush entries prematurely, thereby possibly causing leakage of frames to improper ports until the MAC addresses are learnt again, but we didn't find any misconfiguration at the spanning-tree.
Does anyone have a better idea about this issues, and how to find out if is the spanning-tree that causes this?
We're using LAN hierarchical design:
11-24-2015 10:47 PM
if the unexpected traffic you're seeing is flooded unicast after CAM table flushes caused by STP topology changes ("TCs"), you can use the 'show spanning-tree detail' command to see where the last TC came from. I always use it with an RegExp which provides a handy output:
show spanning-tree detail | include exec|occur|from
It depends on the STP version which kind of events trigger TCs, so it would be interesting to know if you use RSTP or the legacy version or a mix of both. All Cisco or 3rd-party as well?
Often TCs are caused by ports to end devices without portfast configuration, so make sure that portfast is configured on all the edge ports.
If you see frequent changes in your STP topology, you could also enable 'spanning-tree logging' on your switches (or some of them) to track where the changes come from.
Rolf
