Upgrade Cat6500 doc info
hjacquemin
Hello everyone,
I have successfully upgraded both 6509's, but the mentioned “0 to 3 seconds switchover time” (SSO mode) in the “Catalyst 6000/6500 Series Switches with Redundant Supervisor Engines Software Image Upgrade Configuration Example” was a little bit underestimated.
I experienced longer switchover due to a reset of all cards (exept the SUP720). This was a bit unexpected. Can you give any reason for this?
And will this happen again in a future upgrade?
We also wonder if the card rebooted at the same time or one per one?
Someone has a document who explained that?
Mark Yeates
Level 7
Level 7
Herve,
Are you running SSO/NSF? Running NSF along with SSO will dramatically cut down fail over times within your chassis. Please see the following link.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DC_Infra2_5/DCInfra_7.html#wp1136155
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd801c5cd7.html
HTH,
Mark
hjacquemin
I already had this information, but I still have no info on what happens with the line cards during a “high availability software upgrade”…
Do they reboot?
At the same time?
One after the other?
for information, I'm in SSO mode.
stierb
Your question is answered in the document you referenced (the document id should be 71585). The explanation is under step 12 of the Software Update/Native Mode section. To summarize, after you upgrade the standby sup, it will come up in RPR mode because the IOS versions don't match.
Will it happen in a future upgrade? Yes.
Also, the linecards all reset at the time the failover occurs.
