Upgrade ROMMON SP 6509 Gold region
s k
Hi, I am trying to upgrade the ROMON on one of the 6509 redundant device. The current config shows as below
MYDEVICE>sh rom-monitor slot 5 rp
Region F1: APPROVED, preferred
Region F2: INVALID
Currently running ROMMON from F1 region
MYDEVICE>sh rom-monitor slot 5 sp
Region F1: FIRST_RUN, preferred
Region F2: INVALID
Currently running ROMMON from S (Gold) region
MYDEVICE>sh rom-monitor slot 6 rp
Region F2: INVALID
MYDEVICE>sh rom-monitor slot 6 sp
Region F2: INVALID
I want to upgrade the rom-monitor slot 5 sp using "upgrade rom-monitor slot 5 sp file bootflash:c6ksup720-rm2.srec.8-5-3.srec "
I wonder what would be the output after reload? Will it show as below? To be precise, what region would the new firmware run on? F1? F2? or GOLD?
Region F2: INVALID
Thanks for the answer!
Joseph W. Doherty
I recall (?) it will use your unused region, F2.
In other words, will this be the output after upgrade and reload commands?
Region F1:APPROVED
Region F2:APPROVED, preferred
Currently running ROMMON from F2 region
That's what I recall (?).
