Upgrade stacking 2960x
Imran Asri
What is the difference between a normal archive download-sw  and archive download-sw /leave-old-sw ?
If i use normal archive download-sw it will delete the previous file and it wont corrupt the switch right ? I did this because the space is full and i cannot do the leave-old-sw command.
Appreciate your help. Thank you
7 Replies 7
Leo Laohoo
The /force-reload or /reload will reboot the stack after files have been extracted.  Without either one of these, the stack will not reboot until instructed otherwise (or someone kicks the power).
So the switch will remain using the old one eventho i have deleted and replace with new one ?
Until the stack gets rebooted.
Upgrade from ex5 to e7. This is consider okay right ?
Sure.  E7 is fine.
Thank you sir for your help appreciate it
Where did you source the switches in the stack?
