Upgrade WS-C4500X-32
themizzz21
We need to upgrade a WS-C4500X-32 to the latest version: 03.11.07.E.152-7.E7
Current Version 03.08.07.E
Current rommon version: ROM: 15.0(1r)SG10
We do not plan to use VSS.
Do we need to upgrade the rommon too?
Thank you very much.
6 Replies 6
Leo Laohoo
It does not hurt to upgrade the ROMMON when opportunity presents itself.
themizzz21
I just want to verify that there is no issue upgrading from 03.08.07.E to 03.11.07.E and keep rommon the same version: 15.0(1r)SG10.
Thanks again.
ROMMON Upgrade take place when it required, i do not believe you have option of what ROMMON you need, new version may need to upgrade ROMMON. you can find that information in release notes.
BB
Rommon will be upgraded automatically with the upgrade of the switch if needed.
BR
****Kindly rate all useful posts*****
This is a Catalyst 4500 family of switches.  ROMMON upgrade is manual.
apologies - i missed that bit of Cat 4500 - what @Leo Laohoo  stated correct.
BB
