04-09-2026
02:20 AM
- last edited on
04-09-2026
04:40 AM
by
Obulesu
i was wondering what methods people use to upgrade alot of switches at the same time, if you dont have dna license?
i have tried to make some jobs via cattools for diffrente model switches, but its a pain with c9200 but works fine with 9300.
so i am looking for a Smarter method.
what are you guys using? ansible? or something else .
pros and cons?
04-09-2026 05:02 AM
Generally I'd like to perform it manually, since it's just copy the image and issuing the upgrade command.
But if you have that many switches, I would say Python with Netmiko and Getpass for sure can help, you can build pretty much any sequence of commands and validations to automate as much you like.
04-09-2026 05:09 AM
- @martacarl90 I don't recommend upgrading switches at the same time, it does not mean that a tool
could be useful to schedule upgrades in cascade, the reason being that it's important
to keep track if upgrades are successful per device; for instance if the first one fails
it's important that you can stop the train
M.
