Upgrading IOS using tftp
kartik.shah1
We have 2960x-48ts-l.
we want to upgrade/downgrade IOS to match to exisitng stack.
can anyone help me with correct steps for upgrading/downgrading firmware using tftp server.
thanks,,
Leo Laohoo
The Release Notes will provide detailed instructions on how to upgrade the IOS.
Follow this if you haven't done it before it walks you through tftp process, once it has the same ios as the other switches in the stack you can just pop it in the stack and it should sync up , check the show ver to see it has
https://www.youtube.com/watch?v=8cmF-aPEbgs
Julio E. Moisa
Additional to Mark's comments, this link can be useful:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/file_management/file_management/img_files.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
