Urgent Help For Configuring Switch-Please Help
rania20052006
Dear All,
I have here in my company 25 Cisco Switch 3560 .
as i know, i will configure the Switch with the Basic configuration like Hostname & IP-Address - & Gateway.
My 2 question is :-
1- if i configure the switch with the Basic Configuration like IP-Address & Subnet mask & So on , where its saved on the Switch Exactly ?
2- instead of have the 25 Switch in-front of me , and assign each switch his configuration like IP-Address & all the Things, is there any way to copy the Configurations from the switch which i configured on the Text file & then on each switch i will modify the Text file which include the configuration for that switch ( New configuration ) & then apply to that switch ( the New one ) ?
if i can do like that , can i & HOW CAN I DO IT , PLEASE HELP ME BY WRITING THE COMMAND WHICH I NEED TO FOLLOW IT ?
Thanks .
Rania.
Richard Burts
You have posted exactly the same question on the WAN Routing and Switching forum where it has already gotten some response. I suggest that we consolidate any discussion to that forum.
Rick
Rick
