Username without admin privilege
DO344-itcaucedo
Good day everyone,
i need to create a Read-only and i already created it in my switch. As soon as i place the username and password it goes straight to global configuration. I need to set it that after i place the credentials it goes to switch>
Please help
it is unclear what you are trying to achieve. Please clarify (in proper English)...
Ok again: I need to create a read-only user but as soon as i create it, it goes straight to global mode.
I am trying this: switch(config)# username user privilege 5 password password
So when i try to log in, Instead of Switch> it goes stright to Switch#
have you set up an enable password?
can you post your vty line config ?
BB
Hello
Its either you have specifed it to do that in any AAA configuration you have running or on the specifc vty lines, Can post the config for both please.
Kind Regards
Paul
