I need to monitor network traffic going through a 4006 switch running CAT OS. All traffic is on VLAN 1. I have a port sniffer PC setup and connected to two ports on this switch, the sniffer is on port 6/2, I want to direct all traffic through this port so it can be monitored. So far I have not been able to make it work. I have the following code in place but it is not working:
switch port analyzer
set span 1 6/2 both inpkts enable learning enable create
Let me know if you need the entire config posted. Anyone have ideas?
Mitchell
