VACL on switch WS-C3750X-24T-L
amolak_cisco
I am trying to configure VACL capture on switch WS-C3750X-24T-L (IOS Code – c3750e-universalk9-mz.150-1.SE2.bin).
ip access-list extended IDS
permit ip any any
vlan access-map IDS-map
action forward capture                                   <<< not available
match ip address IDS
vlan filter IDS-map vlan-list 100
interface Gi1/0/3
description IDS-Monitor-Port
            switchport capture                                        <<< not available
            switchport capture allowed vlan 100            <<< not available
Please advice if this is a IOS code issue or these commands are not at all supported on this switch model.
Thanks in advance.
Amolak
Reza Sharifi
The switch port capture commands are not available on the 3750 series switches.
Reza Sharifi
Thanks Reza. I got the reply from Cisco as well - "The VACL capture concept is unique to the 6500/7600 architecture hardware ASICs.   For a 3750x,  you have to use the monitor session/Local SPAN type configuration for packet mirroring."
