VACL
Hiko
Hi Dear Friend
İ need some explain about VACL i sharing simple scenario
i am clearly understand that i creat vlan and standart access-list after we are creating vlan-access -map and match ip address access list number ok  action forward  i understand that  if we want forward  access list ip we must use forward  but why we must use drop ? at the same vlan acces map ?please explain me thanks a lot
SWITCH_A(conf)#VLAN 10
SWITCH_A(conf)#VLAN 30
SWITCH_A(conf)#access-list 1 permit 10.1.10.0  0.0.0.255
SWITCH_A(conf)#vlan access-map DEMO 10
SWITCH_A(config-access-map)#match ip address 1
SWITCH_A(config-access-map)#action forward
SWITCH_A(conf)#vlan access-map DEMO 20
SWITCH_A(config-access-map)#action drop
SWITCH_A(conf)#vlan filter DEMO vlan-list 10
8 Replies 8
Seb Rupik
Hi there,
It is worth noting that a VACL has an implicit deny any at the end.
In your case, line 20 does not contain a match clause so will match all traffic, and then drop it. This is redundant behaviour because of the implicit drop
Cheers,
Seb.
first we do access-list 1 permit 10.1.10.0 0.0.0.255 i know that is permit this network for traffic but after can we do drop this network in acces-map ? if yes it is possible i have new question why we do permit acces-list and after drop can i do deny access-list first time?
The purpose of the access-list in this scenario is to match packets for processing by the access-map.
Suppose you wanted to apply an action to a whole /24 subnet except for a single host, you would use the following:
access-list 1 deny 10.1.10.100  0.0.0.0
This would not match on the host IP of 10.1.10.100 but would match on the rest of the subnet.
Going back to your example, if you wanted to drop all traffic from that subnet using the access-map then simply issue an action drop for that clause:
  match ip address 1
  action drop
…but since a VLAN typically only contains one subnet, matching to then drop is a bit pointless. You should just remove the match statement entirely.
  action drop
cheers,
Seb.
thanks but i want know that can i use deny in access-list ? if i use deny can i forward ? i think no at this reason i think that only me must use permit in access-list after if we can use forward or drop yes? can i explain my opinion?
In the context of a VACL access-map, the ACL is used only for packet matching not for filtering. (in the same way one is used in a NAT ACL)
So, yes you can use a deny statement in the ACL, this will have the effect of NOT matching (ie exclude the host from the access-map match clause). These NOT MATCHED packets will still be forwarded.
Take this pointless example:
  match ip address 1
  action forward
  action forward
Although you have denied 10.1.10.100 and permitted the rest of the /24 subnet in the ACL , you will find by the time the VACL has finished processing, the traffic flows for 10.1.10.100 will be unaffected.
Cheers,
Seb.
Hello
Just like to add , a VACL map with no match or action statement by default forwards traffic so regards sebs last example just creation of the second stanza would be good enough to forward all other traffic.
Kind Regards
Paul
Hi @paul driver ,
I don't doubt your knowledge, but your statement has made me do a bit of document digging and I am reading some conflicting sources.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vlan_acls.html#14906
..says "If a VACL is configured for a packet type, and a packet of that type does not match the VACL, the default action is to deny the packet."
A bit further down an example:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vlan_acls.html#30702
..says "In this example, IP traffic matching net_10 is forwarded and all other IP packets are dropped due to the default drop action."
Are you suggesting that an empty stanza has an a implicit permit? So without a match clause it will match and permit all the reaming packets?
  match ip address 1
  action forward
But if for example there was no sequence #20 then the remaining traffic would hit the implicit deny?
  match ip address 1
  action forward
That seems like a subtle gotcha I've never noticed! I wish I had some hardware here at home to test this on!
cheers,
Seb.
Hello Seb
Correct , My understanding there is "invisible" deny at the end of every VACL
So say your just VACL statements are in bold
There will be applied a an invisible drop clause which wont get hit because clause two forwarding everything :
1) vlan access-map VACL
match ACL
action drop
2) vlan access-map VACL
3) (vlan access-map VACL  ( implict )
action drop)
However say you applied this
match ACL
action forward
2) (vlan access-map VACL  ( implict )
action drop)
Again there will be applied a an invisible drop clause which this time will get hit because clause 1is only forwarding specify whats defined in the matched acl
So in summary:
without any stanza = default implicit deny
with stanza + match clause and no defined action = default implicit deny
with empty stanza = default implicit permit
Kind Regards
Paul
