vdc nexus 7000
Rodrigo Bezerra
created the vdc, allocate interfaces, but when I do a show running in vdc interfaces not appear.
could help me?? thank you.
8 Replies 8
Reza Sharifi
When you are in admin VDC, when you do a "sh run" do you see the interfaces being allocated the vpc you created?
what is the output of sh run in admin vdc?
What type of modules you have in the chassis?
I am using the Module N7K-F248XP-25 and when I do the show running, only see the interfaces allocate the vdc_1. But allocation interfaces for vcd_2 and does not appear, reload in need Make nexus7k to appear in the interfaces that allocation vdc_2?
Thank you.
No, there is no need for reload.  What type of module is allocated to vdc_1?
Also have a look at this link.  You may not be grouping the ports together correctly.
On the Cisco Nexus 7000 Series 48-port, 10-Gbps  Ethernet module N7K-F248XP-25[E], you must allocate the interfaces on  your physical device in the specified combination. This module has 12  port groups that consist of 4 ports each (4 interfaces x 12 port groups =  48 interfaces). Interfaces belonging to the same port group must belong  to the same VDC
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/vdc_mgmt.html
I allocate the interfaces correctly in vdc_2, I must say that I am using to module interfaces up? therefore not applied the command to specify the module.
Thank you
before creating the VDC_2 interfaces was already allocated for VDC_1 and now allocate to vdc2 and does not appear interfaces,
Can you post "sh run all" from the admin vdc?
today i am free tomorrow but I put the show run all thank you.
I believe that the interfaces are being not allocate due to VDC_2 not this the correct module.
My doubt is that I will be changing I will cause a problem in the interface due vdc_1 are already allocated to it?
vdc CORSWBETANXS01 id 1
  limit-resource module-type f2
  cpu-share 5
  ha-policy single-sup reload dual-sup switchover
  allocate interface Ethernet3/1-48
  allocate interface Ethernet4/1-48
limit-resource vlan minimum 16 maximum 4094
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource monitor-session-erspan-dst minimum 0 maximum 23
  limit-resource vrf minimum 2 maximum 4096
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 96 maximum 96
  limit-resource u6route-mem minimum 24 maximum 24
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
  limit-resource monitor-session-inband-src minimum 0 maximum 1
vdc BORDA1 id 2
  limit-resource module-type m1 f1 m1xl m2xl
  cpu-share 5
  ha-policy single-sup restart dual-sup switchover
  boot-order 1
  limit-resource u4route-mem minimum 8 maximum 8
  limit-resource u6route-mem minimum 4 maximum 4
  limit-resource m4route-mem minimum 8 maximum 8
