02-13-2015 11:10 AM - edited 03-07-2019 10:38 PM
Hi all,
I want to know, Why VFC not supported over VPC. Like I have one Nexus 5548UP as a access switch and two N5K UP model upwards having in VPC with downstream nexus 5548UP like a triangle. I want to configure VFC between VPC but it is not supported i think.
Solution is : I have to make VFC with different links other than vpc member ports. Means between one to one switch not in one to multiple switch in VPC
Kindly help...
02-13-2015 12:24 PM
Edit - mistook your question to include line cards, which would not be a vPC. My apologies. As you mentioned I do not believe you can do VFC over a vPC because that traffic is not allowed over the vPC peer link.
Logan
02-13-2015 12:45 PM
In FCoE, If fibre(Storage) traffic not supported over VPC peer link. Then i have a scenario in my data center.
I have a net app filer that connected to my down N5k switches in vpc and vfc also running over vpc. Now in that case how traffic flow over VPC peer link.
Can you explain?
