Virtual Port Channel on different line cards problem
Thibault BRISSE
Beginner
Beginner
It is possible to add interface from different line cards reference ( for example N7K-148GT-11L and N7K-F132XP-15 ) to a vPC ?
I ask you because I try it and I have the following error :
command failed: port not compatible [Capabilities FabricPath]
Thank you,
Thibault
rsimoni
Hi Thibault,
no, unfortunately you cannot mix M1 with F1 ports within the same portchannel (not necessarily vPC).
It is documented here:
http://cco/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_portchannel.html#wp1888267
'You cannot configure the ports from a F1 and an M1 series linecard in the same port channel because the ports will fail to meet the compatibility requirements.'
regards,
Riccardo
Recognize Your Peers
