vlan bridging on ASR1001
Manoj Buddhika
I have following requirements to implement on cisco asr1001 router.
1.G0/0/0 and G0/0/1 interfaces are connected to a swith through trunk. Multiple customers
   are will be using this trunk interface . Each customer will have subinterface with dot1q tag.
2 I want both sides of the ASR1001 to be in same segment .
3 If above two is possible I would like to implement shaping on each customers sub-interface level
is above implementation is possible on asr1001. if possible please me example configration and
ios information. I found a technology called EVC . but I am not sure is that the one suited for me.
network diagram is attached seperately. Please have look.
Thank you
This can be obtained with EVC and bridge-groups per VLAN.
I still unable to configure this task. could someone pls provide me configuration example .
thank you
jingt0829
You will need something like below:
interface GigabitEthernet0/0/2
service instance 1 ethernet
  encapsulation dot1q 100
  rewrite ingress tag pop 1 symmetric
  bridge-domain 1
interface GigabitEthernet0/0/3
  encapsulation dot1q 200
  bridge-domain 1
Please refer to:
http://www.cisco.com/en/US/docs/ios/ios_xe/cether/configuration/guide/ce_evc-infra_xe.pdf
