07-15-2014 02:20 PM - edited 03-07-2019 08:04 PM
Hi all,
I have the following physical topology:
Router Cisco 2851 <-----> some huawei and raisecom switches <-----> Switch Cisco WS-C2960-24TT-L <------> Ubnt in AP mode
In C2960 there are a lot of warnings regarding to mac flapping:
Jul 15 18:11:51.626: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.5443.f6dx in vlan 101 is flapping between port Fa0/6 and port Fa0/20
Port Fa0/6 goes to Ubnt Wireless AP and Port F0/20 goes to Cisco 2851.
001b.5443.f6dx is the default gateway for Ubnt's MGMT and C2960 is trying to learn that MAC address from F0/6, which is a strange behavior
Many thx for your time,
-d
07-15-2014 03:34 PM
Hey,
This mac flap notification says switch is seeing host 001b.5443.f6dx on these two ports. Is there any connection between Ubnt and huawei and raisecom switches?
HTH.
RS.
07-22-2014 08:20 AM
Hi rajeevsh,
I was investigating further and I found that a couple of switches along the path have not configured STP, as follows:
Huawei Swtich
dis stp brief
MSTID Port Role STP State Protection
0 Ethernet0/0/1 DESI FORWARDING NONE
0 Ethernet0/0/2 DESI FORWARDING NONE
0 Ethernet0/0/3 DESI FORWARDING NONE
0 Ethernet0/0/4 DESI FORWARDING NONE
0 Ethernet0/0/6 DESI FORWARDING NONE
0 Ethernet0/0/7 DESI FORWARDING NONE
0 Ethernet0/0/8 DESI FORWARDING NONE
0 Ethernet0/0/24 DESI FORWARDING NONE
Raisecom Switch
sh spanning-tree detail
MSTP Admin State: Disable
Protocol Mode: MSTP
Would it be possible that these misconfigurations being causing mac flapping?
Thx,
-d
07-22-2014 01:15 PM
Hey,
Its best to draw a layer 2 topology and check how it is connected. Its a high possibility that we are seeing syslog due this switch as when STP is disabled switch starts acting like hub.
HTH.
RS.
