VLAN Help
rmwhite59
I have an AP connected to FA0/1 and FA0/3 is connected th a ASA 5505. VLAN 20 is a secure wireless vlan and VLAN 30 is a unsecure wireless vlan. All vlans can get to the internet but I can no longer access the switch or any device attatched to the switch Configuration attached
Edison Ortiz
The only management IP on this switch is located under Vlan1.
Vlan1 is in shutdown mode. no shut the SVI and you should have Layer3 connectivity provided that's the right subnet for Vlan1.
HTH,
__
Edison.
