VLAN traffic question
bryanrobh
I have a network that has layer 2 links across all the switches the only layer 3 routing is done at the distro switch.  Now I use VTP to redistribute all the VLANs across all the switches.  Some of the switches do not use all the VLANs.  I have someone telling me that having unused VLANs on a switch will cause unnecessary traffic due to broadcasting on said VLAN.  When I do a show mac address-table vlan XXX on a switch that isn't using that VLAN it has all the MAC addresses from other devices in that VLAN from other switches.  They are saying this is the problem.  Does having an unused VLAN on a switch cause traffic to it?  And if so is there some document to show how much traffic if any?
Carlos Villagran
Hi!
It will, yes. Broadcasting, Unknown Unicasts, ARPs, etc will be seen in the VLANs of those switches. How much traffic will be seen depend on many factors regarding your network design, also how much it would affect your switches depends on the switch capacity itself.
VTP Pruning is the tools used to avoid that kind of traffic, since it denies unnecessary traffic because switches communicate they have no access ports belonging to x vlan so it is not necessary to send traffic to them. Please refer to the following link for detailed information about VTP Pruning:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25ew/configuration/guide/conf/vtp.html
Basically, use  switch(config)#vtp pruning
Hop it helps, Best regards!
JC
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Carlos has already noted, trunks will forward any VLAN frames that is doesn't have a unicast MAC in its MAC table.
As he also noted, VTP provides a pruning feature that will block VLAN traffic, down trunks, when there are no ports in that VLAN downstream.
