Vlan Trunking issue
Aaron Alvarado
I need some help setting up  L3 Cisco 3560 for my VM lab. I have setup a few vlans and at this point I am trying to test out routing and connectivity. I came across with two issues and I am trying to get good advise from the experst since I am not
The Cisco 3560 is directly connected to my home router gi0/4 192.168.10.0/24 which would be my internet connection. The home router default gateway is 192.168.10.1.
I created Vlan192 on the 3560 to interact with the home router and get me to the outside world from the core. Obviously I'm doing something wrong here and came across 2 issues.
1- I tried setting Fas0/2 as trunk port and using the vlan226 on my pc but it wont work when I set this to my computer. It wont route to all vlans and I am not able to ping this 10.23.226.9 address from the 3560. The only way this works for me is if I set the IP to the 192 range which is my native Vlan, but anything other from 192 wont route.
PC IP address
10.23.226.9
255.255.255.0
10.23.226.254
Fas0/2 configurartion
switchport trunk allowed vlan 192,224-229
switchport mode trunk
Please see my entire config below and maybe you can help since I am not an expert on this.
zeus-sw1#sh run
Building configuration...
Current configuration : 5364 bytes
version 12.2
no service pad
hostname zeus-sw1
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$E9/L$UAOdxa6S.6QT52G2Lgcll0
enable
username admin1 privilege 15 secret 5 $1$hlCW$laTgSRIXF2LnZO.wyd0k0/
aaa new-model
aaa session-id common
system mtu routing 1500
vtp mode transparent
ip routing
crypto pki trustpoint TP-self-signed-13407744
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-13407744
revocation-check none
rsakeypair TP-self-signed-13407744
crypto pki certificate chain TP-self-signed-13407744
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333430 37373434 301E170D 39333033 30313030 31393031
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D313334 30373734
  3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100BC82
  4A857145 B3984EBF ED1553C2 E23AF1CF 60B5CB00 96984A72 CEC9F4CC 09CA7B8D
  7416102A E630D17C 66716B57 DF7991AB 87DE6EBD DADE5539 F0278510 70BE7391
  F2EC292D DF0C707A 70083E80 D19F4D3D 31462E89 5EE310EE 4976F764 AB1592C1
  2A8EE610 C3B11D76 252568A7 2AE260B7 4C9141AB C8358A4A B76B94BF 6E970203
  010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603 551D1104
  0D300B82 097A6575 732D7377 312E301F 0603551D 23041830 16801487 8F7A7E29
  112BA5CC 42E2E9E0 0A9C5ACF 6CCBD330 1D060355 1D0E0416 0414878F 7A7E2911
  2BA5CC42 E2E9E00A 9C5ACF6C CBD3300D 06092A86 4886F70D 01010405 00038181
  0059DAD2 5601B324 2B1E4143 9CE67677 45100C44 DC21364D 175CB8F2 178B0EBC
  D39D603F 8F896ADB 4CEEA493 13D8C028 F805F67B 9C7D6BA4 D195B7F3 FEED6763
  F03F4575 B768C6FB 9A783232 DCC60120 9F72B78C 9B5C1B7A FD1C78D7 A3DF7BFE
  483E46E6 7CA84A6C 95F37C63 BEA804F9 E535520E 629AE46E 0752BE69 42781471 21
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 192
name NativeVlan
vlan 224
name iSCSI
vlan 225
name ESX_MGMT
vlan 226
name VM_SERVERS
vlan 227
name VMOTION
vlan 228
name VIEWDESKTOPS
vlan 229
name VCLOUD
lldp run
interface FastEthernet0/1
interface FastEthernet0/2
switchport trunk native vlan 192
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
description LINK SG200 UNTAGGED
interface Vlan1
no ip address
interface Vlan192
ip address 192.168.10.254 255.255.255.0
interface Vlan224
description iSCSI
ip address 10.23.224.254 255.255.255.0
interface Vlan225
description ESX
ip address 10.23.225.254 255.255.255.0
interface Vlan226
description VM_SERVERS
ip address 10.23.226.254 255.255.255.0
ip helper-address 10.23.226.2
interface Vlan227
description VIEWDESKTOPS
ip address 10.23.227.254 255.255.255.0
interface Vlan228
description vCloudDir
ip address 10.23.228.254 255.255.255.0
interface Vlan229
description SERVERS
ip address 10.23.229.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip http server
ip http authentication local
no ip http secure-server
end
glen.grant
  I would just set up the port as an access port for your pc , not a trunk .  Make sure any firewalls on your pc are off before testing anything.   You will need at least a single device in the other vlans active or  a  active trunk link with all your vlans allowed  to make the SVI's active so you can ping them .   Most pc nics aren't capable of trunking to an interface .
7 Replies 7
glen.grant
Glen,
Thanks for your advise. After changing the port as an access port I am able ping all vlans and my gateway from my home router 192.168.10.1, However a new issues came up. I am not able to get to the internet.
It seems it works from the 3560:
zeus-sw1#ping yahoo.com
Translating "yahoo.com"...domain server (255.255.255.255) [OK]
Sending 5, 100-byte ICMP Echos to 206.190.36.45, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 76/94/134 ms
zeus-sw1#
It wont work from my pc:
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::3d53:efc0:ea00:9bd2%3
   IPv4 Address. . . . . . . . . . . : 10.23.226.9
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 10.23.226.254
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter isatap.{461494F6-EA41-42CC-8B0A-B5BD2D8097DA}:
C:\Users\user1>ping google.com
Ping request could not find host google.com. Please check the name and try agai
.C:\Users\user1>ping 14.2.2.2
Pinging 14.2.2.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 14.2.2.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
     Where is your internet connection coming in from the internet, which port ?  What kind of router is it ?
rom the 3560 is conming from gi0/1.   This port is connected to my traditional home router(TrendNet) which is connected to my comcast cable. The trendnet router gateway is 192.168.10.1 and I added static routes to point to it, but no luck. Again I am newbie on this and I might not make sense.
description LINK TO ISP UNTAGGED
Static routes:
Config connection:
  Your uplink should not be a trunk , try making it an access port in vlan 192 and see what happens.
no switchport trunk encapsulation dot1q
no switchport trunk native vlan 192
no switchport trunk allowed vlan 192,224-229
switchport mode access
switchport access vlan 192
I change the uplink port to acces mode and added vlan 192 as shown above and the internet works, however other vlans wont get to the internet.  For instance I changed fas0/2 which is my pc connection to acces mode vlan 226 and set the static IP 10.23.226.9 with its gateway 226.254 and I still cannot get to the internet. I am able o ping everything else but internet wont work.
fas0/2 is set
switchport access vlan 226
uplink is set as advised above. Tried adding vlan 226 instead of 192 but no luck.
Thanks in advance for all your help.
Ok. I have been doing some research and the issue is no longer vlan trunking. My real problem now is how to NAT all my internal vlan/subnets from my home router to the Cisco L3 3560. Is there a way to trick my home router to  NAT all vlans on my 3560 and make them accessible to the internet.
