VLAN vs Control/Mangement/Data Protocols
169.254.X.Y
I am currently studying for ICND1. I just suddently got curious which VLAN do protocols use.
I guess my questions is pretty not worthy, but I desparately want to know. I tested some protocols I have learned on the Packet Tracer and figured out that CDP, VTP, PAgP somehow always use VLAN1 no matter VLAN1 is a native VLAN or blocked from the trunk port. DTP seems to always use the native VLAN. I googled about this and figured out that control and management protocols always use VLAN1. However, I don't think this is the right answer cuz according  ARP and ICMP are considered as Control Plane protocol, but when I tested, they didn't always use VLAN1.
Mark Malone
The control protocols are sent using vlan 1 even when its shutdown thats why its recommenemded not to use vlan1 for production traffic as your mixing it with control traffic
Best practice shut vlan 1 down diss-allow from trunk and then only control traffic passes it and no transit traffic , if you shut it down and still allow on trunk as native vlan your susceptible still to attacks and flooding
1 if you want further classifcation of control protiocl you can use a feature called CoPP
2 CDP/PAGP/VTP are some of them
3 You can control ICMP in the control plane to rate limit if required to prevent issues   , read below on ICMP https://learningnetwork.cisco.com/thread/81815
5 Replies 5
Mark Malone
Thank you very much :)
My friend who has a CCNP Cert told me that it is possible to remove the VLAN 1 in CISCO SW. Is it true? I have been thought it is impossible to remove the VLAN 1.
No not possible as even when shutdown at l3 and no ports assigned it carries the control protocols
