VLAN with Sonicwall & 2970G
troy.lynch
   Having a strange problem which this setup has always worked before. I have a sonic wall with vlan 1 and vlan 30 and I've got a couple ports with access vlan 30 on them but its not pulling dhcp from vlan 30 from the sonicwall. Attached is my config. I've taken this setup to other switches different models and brands and everything works fine so I know the Sonicwall side is setup right.
Here's my Trunk port
interface GigabitEthernet0/1
 switchport trunk allowed vlan 1-500
 switchport mode trunk
My Access port
interface GigabitEthernet0/3
 switchport access vlan 30
Then my vlans
interface Vlan1
 ip address 192.168.50.249 255.255.255.0
 no ip route-cache
interface Vlan30
 ip address 192.168.30.254 255.255.255.0
 no ip route-cache
Pretty straight forward setup or so I thought. Any help on where to look would be great! Thanks in advance
did you create the layer-2 vlan
config t
vlan 30
name firewall-vlan
exit
does "sh vlan summary" show vlan 30 and port gi0/3 active in it?
sh vlan summary
or
sh vlan id 30
7 Replies 7
Reza Sharifi
If vlan 1 needs to get IP from vlan 30, than you need to add "ip helper-address 192.168.30.xx command under vlan 1 interface.
This is assuming the vlans are in up and up mode and so are the physical interfaces.
Nope vlan 30 is getting dhcp from dhcp running on vlan30 on the sonicwall. dhcp on vlan1 is coming from the windows environment.
Do you have default-gatway or default route on the switch pointing to the firewall (vlan 30)?
Nope. There is no default gateway for vlan30 and shouldn't be that would be on the clients. Which I do have set. I can't even ping the default gateway on the vlan so the vlan traffic isn't going from the access port to the trunk port.
config t
vlan 30
name firewall-vlan
exit
sh vlan summary
or
sh vlan id 30
That was it! Thanks
I've also tried static and ping the vlan 30 gateway from the access port vlan 30 which its not passing the traffic to the sonicwall
