VLSM odd problem
lostrouter
Today I was setting up a small network for a new client with the following equipment, 881 router,  2960 switch and a 1041 accesspoint.  The customer wanted 2 things,  a private LAN for their employees and a guest LAN via WIFI that was able to access the internet and nothing else.   I set this up and everything is working but here is my odd question and I am hoping someone can explain it to me so that I can understand why it would not work my original way.
Original network design.
Interface vlan1
     description Admin network for cisco equipment
     ip address 192.168.1.1 255.255.255.248
interface vlan2
     description Private network for employees
     ip address 192.168.1.9 255.255.255.224
interface vlan3
     description Guest network
     ip address 192.168.1.41 255.255.255.240
So that was my original plan,  but when I would try to apply the IP for interface vlan2, it would throw and error saying the ip overlapped with vlan1.  I do not understand this because  vlan1's network was 192.168.1.0 /29  so 192.168.1.0 - 192.168.1.7.  I am not sure why 192.168.1.8 /27 would overlap 192.168.1.8 - 192.168.1.39?
After being frustrated I ended up changing things around as follows and it worked fine,  which I do not understand why.
Interface vlan1
     ip address 192.168.1.49 255.255.255.248
interface vlan2
     ip address 192.168.1.1 255.255.255.224
interface vlan3
     ip address 192.168.1.33 255.255.255.240
It is the same network design I just did the largest networks first and the smallest last.  So if anyone can explain this to me I would really appreciate it cause I am not getting why it didnt work.
Thanks everyone!
LR
glen.grant
Because the range 192.168.1.9 255.255.255.224  runs from 192.168.1.1 -192.168.1. 30   so it does overlap with your first defined subnet .
