08-18-2021 06:54 AM
One of my clients is rolling out VoIP, so I wanted to use the 'voice vlan'.
interface GigabitEthernet1/0/13 switchport access vlan 1001 switchport mode access switchport voice vlan 200 end
When I plug a Polycom phone it the interface, LLDP does its magic and the phone appears to be on vlan 200. I can verify this by showing the CAM table; however, the phone's MAC address also shows up on vlan 1001. In addition, the interface does not appear to be in a trunk state, which I thought would happen so the proper vlan tag would get applied. When I link a computer downstream from phone, the computer's MAC shows up in 'vlan1001', so everything appears to be working.
However, I was just worried if I should be seeing this interface negotiate and form a 802.1Q port. I am also worried I see the phone's MAC on both vlans.
Switch in question is a 2960x.
08-18-2021 06:57 AM
That is normal behavior. The phone sends CDP/LLDP packets in the untagged VLAN, so that is why the switch has learned that MAC address in the untagged VLAN. Once the device learns the voice vlan, the rest of its traffic should be in that tagged VLAN.
08-18-2021 07:02 AM - edited 08-18-2021 07:02 AM
can you post example :
if i look at the port mac address they show different vlan with respective vlan mac address example :
#show mac address-table interface fastEthernet 3/0/21
Mac Address Table
Vlan Mac Address Type Ports
3 001e.caed.XXXX STATIC Fa3/0/21 <-- voice vlan
30 9457.a5ed.XXXX STATIC Fa3/0/21 <<-- data vlan
Total Mac Addresses for this criterion: 2
08-18-2021 07:09 AM
HI,
I am not on site today for that client, but it looks like this if I remember correctly.
Mac Address Table
30 001e.caed.XXXX STATIC Fa3/0/21
08-18-2021 07:35 AM
post the correct output, so we can look.
