Voice vlan
hipohoneywell
Hi all,
I have a switch with data vlan 5 and a voice vlan 50.
The IP address for vlan 5 is 192.168.5.2 255.255.255.0.
Do I need an IP address for vlan 50 also?
Thanks for your support
Collin Clark
If this switch will be the default gateway for the subnet, then yes. If it is not acting as a gateway then it does not.
Hope that makes sense.
Thanks so much Collin.
You got it again
