Voice Vlan
Sadam
Hi thanks advance
in my network everything working fine. I’m using Cisco 3850 for core. 2960 for access layers. IP phone avaya IP office 500.
           I need to push the data Vlan form the IP phone. How I can do it.
Data vlan 200
IPphone Vlan 10
Thanks.
balaji.bandi
Let me give some steps  to work :
1. You need to have DHCP Server with different IP address or same IP address different netmask.
2. create a Voice and Data VLAN
interface vlan 200
ip address x.x.x.x
ip helper-address z.z.z.z
interface vlan 10
ip address y.y.y.y
3. In DHCP Server configure Option
4. apply the vlan config to interface as example :
interface FastEthernet1/0/2
switchport access vlan 200
switchport mode access
switchport voice vlan 10
more details found here in this document.
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/19580-dhcp-multintwk.html
BB
Hi Frnds,
Sorry for the delay reply.
interface Vlan10
ip address 192.168.10.1 255.255.248.0
ip helper-address 192.168.10.254
interface Vlan200
ip address 10.200.0.1 255.255.240.0
ip helper-address 172.168.8.3
ip pim dense-mode
i did the config before like above at that time i can get the dhcp from vlan 200 but for vlan 10 ip phone not getting the dhcp ip.
thanks advance.
have you setup a DHCP option ?
http://blog.router-switch.com/2013/03/dhcp-option-150-dhcp-option-66/
interface Vlan10
ip helper-address 192.168.10.254     <---- how come you have 2 different Helper address here
interface Vlan200
ip helper-address 172.168.8.3  <---- how come you have 2 different Helper address here
Do you have 2 DHCP Server for voice and Data ?
BB
Hi thanks for guidance.
We have two different dhcp for voice and data.
For the voice dhcp ip pool from the IP PABX.
Data have separate dhcp from the server Vlan.
