12-21-2021 07:00 AM
Are there can distance/latency limitations in using back-to-back vPC as DCI between two Data centres? I am looking at two DCs approx 200 miles apart with average RTT 50 ms.
12-21-2021 07:31 AM
Assuming you are using a provider to hand off the fiber links to you at both ends, it should work fine. You would need long-haul optics at each end.
Log in to Community
