vPC between Nexus 3172TQ and Nexus 31108TC-V
leptonius
Hi guys!
I am trying to configure vPC between Nexus 3172TQ and Nexus 31108TC-V. The "show vpc" output from the Nexus 3172TQ displays that there are some "weird" vPC consistency issues:
Nexus-A# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 101
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : failed
Type-2 inconsistency reason : QoSMgr Network QoS configuration incompatible
vPC role : secondary
Number of vPCs configured : 1
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po101 up 1,490,495
vPC status
Id Port Status Consistency Reason Active vlans
103 Po103 down* failed Local card type does -
not match with peer's
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
Nexus-A# show vpc consistency-parameters vpc 103
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
STP Port Guard 1 Default Default
STP Port Type 1 Default Default
STP MST Simulate PVST 1 Default Default
Allow-Multi-Tag 1 Disabled Disabled
Vlan xlt mapping 1 Disabled Disabled
vPC card type 1 N3K N9K TOR
Allowed VLANs - 1-4094 1-4094
Local suspended VLANs - - -
Nexus-A# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
101 Po101(SU) Eth LACP Eth1/53(P) Eth1/54(P)
103 Po103(SD) Eth LACP Eth1/47(D)
The above vPC config works fine between Nexus 3172TQ boxes without any vPC consistency issues.
My question:
Is vPC compatible between Nexus 3172TQ and Nexus 31108TC-V? If so, do I actually miss some "magic" steps to fire up the vPC between those boxes?
Reza Sharifi
Usually, there is no issue with using vPC between different platforms. In your case, there is some QOS difference between the 2 platforms that is causing the inconsistency problem.
Yes, you are right. By default, there are some Network QoS configuration inconsistency between Nexus 3172TQ and Nexus 31108TC-V regarding vPC:
Nexus-A (Nexus 31108TC-V)
Nexus-B (Nexus 3172TQ)
Nexus-B# sh vpc consistency-parameters global
Legend:
STP MST Simulate PVST 1 Enabled Enabled
STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled,
BPDUFilter, Edge BPDUGuard Disabled Disabled
STP MST Region Name 1 "" ""
STP Disabled 1 None None
STP Mode 1 Rapid-PVST Rapid-PVST
STP Bridge Assurance 1 Enabled Enabled
STP Loopguard 1 Disabled Disabled
STP MST Region Instance to 1
VLAN Mapping
STP MST Region Revision 1 0 0
Interface-vlan admin up 2 490,495 490,495
Interface-vlan routing 2 1,490,495 1,490,495
capability
QoS (Cos) 2 ([0-7], [], [], [], ([0-7], [], [], [],
Network QoS (MTU) 2 (1500, 1500, 1500, (1500, 1500, 1500,
1500, 1500, 1500) 1500, 0, 0)
Network Qos (Pause: 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
T->Enabled, F->Disabled)
Input Queuing (Bandwidth) 2 (100, 0, 0, 0, 0, 0) (0, 0, 0, 0, 0, 0)
Input Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
Priority: T->Enabled,
F->Disabled)
Output Queuing (Bandwidth 2 (100, 0, 0, 0, 0, 0) (100, 0, 0, 0, 0, 0)
Remaining)
Output Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, T, F, F)
F->Disabled)
Here are default System QoS policies for the Nexus-A and Nexus-B respectively:
Nexus-A# sh policy-map system type network-qos
Type network-qos policy-maps
policy-map type network-qos default-nq-policy
class type network-qos c-nq3
match qos-group 3
mtu 1500
class type network-qos c-nq2
match qos-group 2
mtu 1500
class type network-qos c-nq1
match qos-group 1
mtu 1500
class type network-qos c-nq-default
match qos-group 0
mtu 1500
Nexus-A# sh policy-map system type qos
Nexus-A# sh policy-map system type queuing
Service-policy (queuing) output: default-out-policy
policy statistics status: disabled (current status: disabled)
Class-map (queuing): c-out-q3 (match-any)
priority level 1
Class-map (queuing): c-out-q2 (match-any)
bandwidth remaining percent 0
Class-map (queuing): c-out-q1 (match-any)
Class-map (queuing): c-out-q-default (match-any)
bandwidth remaining percent 100
Nexus-B# sh policy-map system type network-qos
  class type network-qos class-default
     match qos-group 0
     mtu 1500
Nexus-B# sh policy-map system type qos
Service-policy (qos) input: default-in-policy
Class-map (qos): class-default (match-any)
Match: any
set qos-group 0
Nexus-B# sh policy-map system type queuing
Service-policy (queuing) input: default-in-policy
Class-map (queuing): class-default (match-any)
bandwidth percent 100
I tried to tailor Network-QoS policy on the Nexus 31108TC-V to somehow match default Network-QoS policy of the Nexus 3172TQ:
policy-map type network-qos my-nq-policy
      mtu 1500
system qos
  service-policy type network-qos my-nq-policy
After applying above config, the vPC type-2 inconsistency (QoSMgr Network QoS configuration incompatible) still remains.
Are there any ideas how to resolve vPC Network QoS inconsistency between boxes?
