Hello ,
I have read and configured what peer-switch command does and it is working as documented . Can you let me know what are the design considerations if i have peer-switch command enabled and running HSRP in a vPC environment .
What i have observed is that " peer-link" is always shown as the root port irrespective of the "peer-switch" command . In this case whenever i disconnect the link from a server switch to the Primary Nexus 7K , inter-vlan routing stops .
Is this a known behavior ?
