VPC question
jeremytetart
Hello Guys,
I have one question for you about vPC.
As shown in attachment, you can see two schemas with three diagrams per schema.
Each schemas are separate.
- Schemas 1, 1-1 & 1-2 are together
- Schemas 2, 2-1 & 2-2 are together
The goal is to understand where the flow pass when Host A ping Host B in vPC topology (without & with failure)
I know :
- schemas 1 & 2 are correct. Hash algorithm determine where the flow pass, either NX5K01 or NX5K02.
- schemas 1-1 & 2-1 are correct. With port link down (schema 1-1) the flow pass by vPC peer-link and without link failure (schema 2-1) the flow pass directly to NX5K02.
However, I don't understand why the network flow pass by the vPC peer-link in case of one vPC port failure (schema 1-1) ?
Is there a mechanism to detect vPC port failure on the upstream switch in order to forward traffic by the other port of the downstream switch ? (exemple in diagram 1-2 & 2-2)
Thank in advance for you clarification
Regards.
7 Replies 7
Jon Marshall
Are the 1-2 and 2-2 examples official documentation or are they your examples ?
I ask because as far as I know an downstream switch cannot detect a vPC port failure for a vPC it is not part of.
Jon
1-2 & 2-2 are my examples.
I ask to me and to the forum if there is a mecanism like spanning-tree backbonefast to detect undirect link failure.
There is no mechanism that I am aware of.
So the downstream switch has no way of knowing a member port of a vPC of which it is not part has failed.
Jon
I'm thought the same thing ;-)
Jon, do you know how the hash algorithm work to loadbalance the network flow between a Nexus 2K & two Nexus 5K ?
Up
Hi Jon,
OK I thought that the loadbalancing was different on NX-OS but not. This is the same as etherchannel on IOS.
https://supportforums.cisco.com/document/12458136/load-balancing-methods-port-channels-nexus#Loadbalancing_Methods
