vrf-light in my Switch 3750
mohamed louhab
Hi ,
i try to configure vrf-light in my two Switch 3750E ,
Firstly i try with the vesion (12.2(35)SE5  C3750E-UNIVERSAL-M ) .
the vrf is supported but when i went to configure EIGRP per vrf i had the message following :
FED_B(config)#router eigrp 1
% Remove all VRFs before configuring EIGRP
secondary , i upgrade the version to ( 12.2(53)SE1 C3750E-UNIVERSALK9-M )
but  this version is not supported by vrf-light . I had the message following when i try to configure  vrf-light :
FED_B(config)#ip vrf USER
% Invalid input detected at '^' marker.
FED_B(config)#ip v?
verify
what can i do to configure vrf-light and the EIGRP per vrf ( for the load balacing)
Reza Sharifi
Hi Mohamed,
VRF is defiantly supported on that image.  You many not have the correct license.  Get with SE  or sales guy to provide you with the key to enable it.
do a "sh licen" to see if you have the correct license.
Switch-B#sh license
Index 1 Feature: ipservices
        Period left: 0  minute  0  second
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
        License Count: Non-Counted
Reza
Hi Reza,
thanks for your reply , i will try that.
thanks
