Join Customer Connection to register!
5959
VRF not supported in 3650
Hi Guys,
need help and suggestion
I am trying to using VRF for my company on serveal 3650 switches, after I input " ip vrf vpn1" command, the system pop up as " the feature does not supported "
I am using a WS-C3650-24TD-S IP BASE switch with Image: CAT3K_CAA-UNIVERSALK9 Version:16.3.5b
1 ACCEPTED SOLUTION
the solution was the commands below:
license right-to-use activate ipservices all
license right-to-use activate ipservices all acceptEULA
6 REPLIES 6
Reza Sharifi
Hall of Fame Expert
IP Base license does not support VRF.  You need to purchase and install "IP Services" license before you can use VRF.
What is the firmware correct ?
That is the solution but if you have not purchased the "IP services license" Cisco will not support it.
par-3650-core#sh license right-to-use
Slot# License Name Type Count Period left
1 ipservices permanet N/A Lifetime
2 ipbase permanent N/A Lifetime
License Level on Reboot: ipservices
soono
*Release Notes for Cisco Catalyst 3650 Series Switches, Cisco IOS XE Everest 16.5.1a
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-5/release_notes/ol-16-5-3650.html#pgfId-1368336
>Whats New in Cisco IOS XE Everest 16.5.1a
3 VRF
Starting with this release, the 3 VRF feature is available at the IP Base license level.
It was previously available only at the IP Services license level.
(IP Base and IP Services)
