Bookmark
Subscribe
530
VRRP issue
w.boerendans
For redundancy I use the command VRRP. I have configured the following
track 1 interface FastEthernet4.6 line-protocol
track 2 ip route 0.0.0.0 0.0.0.0 reachability
Now, I want also add a new track. This track need to check if a specific IP is still alive.
Is this possible and what is the config?
Best regards, Wim
Kyle McKay
For this functionality you will need to track based on IP SLA.
With IP SLA you can track the status of a far-end IP address to determine if it is up and alive.
When implemented with tracking, you can now trigger certain events based on the reachbility of that IP address.
Here is a Cisco guide with some more information:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/sweot.html#wp1085002
