VS-S720-10G Card (6509-E)
d.muralidharan
Beginner
Beginner
What is the ASIC acceptable Temparature range for the VS-S720-10G  card? Please check the current temparature range seen :
BRASWSTA01
Temparature recorded :
module 5 outlet temperature: 39C
  module 5 inlet temperature: 25C
  module 5 device-1 temperature: 30C
  module 5 device-2 temperature: 32C
  module 5 asic-1 temperature: 57C
  module 5 asic-3 temperature: 40C
  module 5 asic-4 temperature: 55C
  module 5 RP outlet temperature: 31C
  module 5 RP inlet temperature: 31C
  module 5 EARL outlet temperature: 32C
  module 5 EARL inlet temperature: 26C
module 5 power-output-fail: OK
  threshold #1 for module 5 power-output-fail:
    (sensor value != 0 ) is system minor alarm
module 5 insufficient cooling: N/A
  threshold #1 for module 5 insufficient cooling:
    (sensor value != 0 ) is system major alarm
module 5 fan-upgrade required: N/A
  threshold #1 for module 5 fan-upgrade required:
module 5 outlet temperature: 38C
  threshold #1 for module 5 outlet temperature:
    (sensor value >= 70C) is system minor alarm
  threshold #2 for module 5 outlet temperature:
    (sensor value >= 85C) is system major alarm
  threshold #1 for module 5 inlet temperature:
    (sensor value >= 65C) is system minor alarm
  threshold #2 for module 5 inlet temperature:
    (sensor value >= 80C) is system major alarm
  threshold #1 for module 5 asic-1 temperature:
    (sensor value >= 90C) is system minor alarm
  threshold #2 for module 5 asic-1 temperature:
    (sensor value >= 105C) is system major alarm
  threshold #1 for module 5 asic-3 temperature:
    (sensor value >= 95C) is system minor alarm
  threshold #2 for module 5 asic-3 temperature:
    (sensor value >= 110C) is system major alarm
  threshold #1 for module 5 asic-4 temperature:
  threshold #2 for module 5 asic-4 temperature:
7 Replies 7
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Hello Deepa,
Was this switch upgraded from a regular 6500 to 6500-E?, if yes the fan trays need to be replaced.
What is the temperature in the room where the switch is sitting?
Reza
The temparature of the room(data center) is fine. Also, there was no upgrade done earlier. Please check the below output as well:
SWITCH#sh idprom module 5 detail
IDPROM for module #5
IDPROM image:
  (FRU is 'Supervisor Engine 720 10GE')
IDPROM image block #0:
  block-signature = 0xABAB, block-version = 3,
  block-length = 160, block-checksum = 6117
  *** common-block ***
  IDPROM capacity (bytes) = 512  IDPROM block-count = 3
  FRU type = (0x6003,0x3FD)
  OEM String = 'Cisco Systems, Inc.'
  Product Number = 'VS-S720-10G'
  Serial Number = 'SAD1151053V'
  Manufacturing Assembly Number = '73-11539-02'
  Manufacturing Assembly Revision = 'B0'
  Manufacturing Assembly Deviation = ''
  Hardware Revision = 2.0
  Manufacturing bits = 0x0  Engineering bits = 0x0
  SNMP OID = 9.12.3.1.9.29.133
  Power Consumption = -540 centiamperes    RMA failure code = 0-0-0-0
  CLEI = COUCADTCAA
  VID = V02
  *** end of common block ***
IDPROM image block #1:
  block-signature = 0x6003, block-version = 2,
  block-length = 103, block-checksum = 3149
  *** linecard specific block ***
  feature-bits =  0x00000000 00000000
  hardware-changes-bits =   0x00000000 00000002
  card index = 254
  mac base = 0017.944A.A72C
  mac_len = 8
  num_processors = 0
  epld_num = 6
  epld_versions = 0003 0003 0002 0001 0002 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000
  port numbers:
    pair #0: type=31, count=02
    pair #1: type=61, count=01
    pair #2: type=60, count=02
    pair #3: type=00, count=00
    pair #4: type=00, count=00
    pair #5: type=00, count=00
    pair #6: type=00, count=00
    pair #7: type=00, count=00
  sram_size = 0
  sensor_thresholds =
    sensor #0: critical = 85 oC, warning = 70 oC
    sensor #1: critical = 80 oC, warning = 65 oC
    sensor #2: critical = -127 oC (sensor present but ignored), warning = -127 oC (sensor present but ignored)
    sensor #3: critical = -127 oC (sensor present but ignored), warning = -127 oC (sensor present but ignored)
    sensor #4: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #5: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #6: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #7: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
  max_connector_power = 1650
  cooling_requirement = 35
  ambient_temp = 55
  *** end of linecard specific block ***
IDPROM image block #2:
  block-signature = 0x6008, block-version = 1,
  block-length = 72, block-checksum = 1189
  *** sensor auxiliary block ***
  num_sensor: 4
  reserved: 0
  sensor_thresholds =
    sensor #0 (major: 105, minor: 90) :
    sensor #1 (major: -128, minor: -128) :
    sensor #2 (major: 110, minor: 95) :
    sensor #3 (major: 110, minor: 95) :
  *** end of sensor auxiliary block ***
End of IDPROM image
krishnakumarr
Beginner
Beginner
Can you provide the show inventory output
regards
krishna
Please find the inventory output details:
SWITCH#sh inventory
NAME: "WS-C6509-E", DESCR: "Cisco Systems Catalyst 6500 9-slot Chassis System"
PID: WS-C6509-E        ,                     VID: V04, SN: SMG1133N6BP
NAME: "WS-C6K-VTT-E 1", DESCR: "VTT-E FRU 1"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K855
NAME: "WS-C6K-VTT-E 2", DESCR: "VTT-E FRU 2"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K876
NAME: "WS-C6K-VTT-E 3", DESCR: "VTT-E FRU 3"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K687
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600          ,                     VID:    , SN: SMT1105H306
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "1", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAL1133XHFL
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 1", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YJJ8
NAME: "2", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAD113403JU
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 2", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YC54
NAME: "4", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAL1134Y31Q
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 4", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1135Z20L
NAME: "5", DESCR: "VS-S720-10G 5 ports Supervisor Engine 720 10GE Rev. 2.0"
PID: VS-S720-10G       ,                     VID: V02, SN: SAD1151053V
NAME: "msfc sub-module of 5", DESCR: "VS-F6K-MSFC3 MSFC3 Daughterboard Rev. 1.0"
PID: VS-F6K-MSFC3      ,                     VID:    , SN: SAD115106E7
NAME: "VS-F6K-PFC3C Policy Feature Card 3 sub-module of 5", DESCR: "VS-F6K-PFC3C Policy Feature Card 3 Rev. 1.0"
PID: VS-F6K-PFC3C      ,                     VID: V01, SN: SAD115103ME
NAME: "7", DESCR: "WS-X6724-SFP CEF720 24 port 1000mb SFP Rev. 2.6"
PID: WS-X6724-SFP      ,                     VID: V02, SN: SAD113309S9
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 7", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YMHD
NAME: "8", DESCR: "WS-X6708-10GE CEF720 8 port 10GE with DFC Rev. 1.3"
PID: WS-X6708-10GE     ,                     VID: V03, SN: SAL1125S4CX
NAME: "WS-F6700-DFC3C Distributed Forwarding Card 3 sub-module of 8", DESCR: "WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.0"
PID: WS-F6700-DFC3C    ,                     VID: V01, SN: SAL1132WY5G
NAME: "Te8/1", DESCR: "10Gbase-SR Te8/1"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901Q5
NAME: "Te8/2", DESCR: "10Gbase-SR Te8/2"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901TX
NAME: "Te8/3", DESCR: "10Gbase-SR Te8/3"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT1129023L
NAME: "Te8/4", DESCR: "10Gbase-SR Te8/4"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901QG
NAME: "Te8/5", DESCR: "10Gbase-SR Te8/5"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT11290261
NAME: "9", DESCR: "WS-SVC-NAM-2 8 ports Network Analysis Module Rev. 4.3"
PID: WS-SVC-NAM-2      ,                     VID: V05, SN: SAD1124060J
NAME: "WS-C6509-E-FAN 1", DESCR: "Enhanced 9-slot Fan Tray 1"
PID: WS-C6509-E-FAN    ,                     VID: V03, SN: DCH11251947
NAME: "PS 1 WS-CAC-6000W", DESCR: "AC power supply, 6000 watt 1"
PID: WS-CAC-6000W      ,                     VID: V04, SN: AZS11290TA2
NAME: "PS 2 WS-CAC-6000W", DESCR: "AC power supply, 6000 watt 2"
PID: WS-CAC-6000W      ,                     VID: V04, SN: AZS11290TAB
krishnakumarr
Beginner
Beginner
hi
pl find the link for VS-s720-10G operating temp and requirements
Fan Tray and Minimum Power Supply Required
• E Chassis supports Cisco Virtual Switching Supervisor Engine 720
• 2500W AC or DC
• Non E Chassis requires the following:
• High-speed fan
• 2500W AC or DC
Environmental Conditions
• Operating temperature: 32 to 104°F (0 to 40°C)
• Storage temperature: -40 to 158°F (-40 to 70°C)
• Relative humidity, operating, noncondensing: 10 to 90%
• Relative humidity, nonoperating, noncondensing: 10 to 95%
• MTBF: Demonstrated 85,000 hours
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759_ps2797_Products_Data_Sheet.html
I did go through this. But I am not able to get the details for ASIC temparature.
Check the below output as well:
SWITCH#  sh idprom module 5 detail
IDPROM image:
  CLEI = COUCADTCAA
  VID = V02
  card index = 254
  mac_len = 8
  num_processors = 0
  epld_num = 6
  port numbers:
  sram_size = 0
  sensor_thresholds =
  ambient_temp = 55
  num_sensor: 4
  reserved: 0
  sensor_thresholds =
End of IDPROM image
krishnakumarr
Beginner
Beginner
Pl provied show envinorment details
regards
krishna kumar
Recognize Your Peers
