Vss 6500 2T
mikegrous
Level 3
Level 3
The Sup 2T has 3 gig ports and 2 10 gig ports
If VSS is setup between 2 6500s with 2 Sup2Ts in each with VSL over 2 of the 8 10 gig links on the supervisors:
Will all 12 of the 1 gig links be usable at the same time for uplinks to other devices?
Can seem to find cisco documentation on this.
Reza Sharifi
Yes, you can use the 10Gig ports and 1Gig ports at the same time.
