06-01-2015 01:46 PM - edited 03-08-2019 12:17 AM
Hello Team Members
Recently we established VSS between C4500X chassis (WS-C4500X-16SFP+) . Everything is working normal.
Both units are logically bundled, there is no issue a far as traffic flow is concerned, however after Chassis merged into
one, Port-channel 2 configuration (defined earlier on Chassis 2) is changed by its own. Before VSS , Port-channel 2 was having the following config .
interface Port-channel2
switchport
switchport mode trunk
switchport nonegotiate
switch virtual link 1
but after VSS, 2 commands are removed on its own on Port-channel 2
interface Port-channel1
switchport
switchport
switch virtual link 2
is it a bug, we are running Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.07.00.E RELEASE SOFTWARE (fc4)
Any Inputs are highly appreciated.
Ahad
Solved! Go to Solution.
06-01-2015 06:58 PM
Hey mansoor,
May be hitting one of the following bugs.
CSCur07401
CSCus77443
hope this helps
Please rate helpful posts,
06-01-2015 06:58 PM
