02-27-2012 07:06 AM - edited 03-07-2019 05:12 AM
Anyone knows if is possible to configure multichassis port-channel between a VSS and 3750X (Port-channel not in the same switch on the 3750X stack). I got it using LACP but I need Pagp to get VSL redundancy “dual-active detection pagp trust channel-group 1”. I am using the last VSS IOS version 15.0(1)SY.
I can’t get the option “switch 1 preempt”, anyone knows if has it changed with other option?
Thank you very much, guys, for your help!
02-27-2012 10:14 AM
Oscar,
Unfortunately, PAgP cannot be enabled on cross-stack EtherChannels. To remedy this problem, use a 1Gig copper port between the 2 VSS switches and utilize the "fast hello" feature instead.
02-27-2012 11:44 PM
Hi Reza,
thanks for your answer. I got this:
You can configure trust mode on a port channel even if there are no interfaces on the port channel or the port channel is a protocol type other than PAgP. The trust mode status is displayed in the show pagp dual-active command output, but no interfaces are displayed.
