VSS Etherchannel Issue ?
mr.marslin
Dear Sir,
Follow the attach file.
Now, I want to run VSS function, but the edge switch two uplink across two ISP link!
Could I setup the etherchannel:
1) VSS & Edge Switch Etherchannel mode ON.
2) Etherchannel load-balance mode:
    VSS --> dat-ip-mac
    Edge Switch --> scr-ip-mac.
Have any issue about this plan ???
Thanks.
Scott Hodgdon
I do not believe you can create a Multi-chassis EtherChannel with the edge switch to the ISP switches. MEC requires two physical switches to appear as one switch, such as in a VSS.
