03-16-2016 11:41 AM - edited 03-08-2019 04:59 AM
Trying to understand how/why using VSS on a pair of 4500x increases the number of port channel supported. Each device supports 64, but when paired with VSS its 256. I would imagine double, but not 4x the number of supported port channels.
any ideas?
many thanks,
Tammy
03-16-2016 11:17 PM
Very good question. This should be the way it is designed/coded (not an answer to your how/why).
I will see if i can find any information and share if i get any.
Cheers
Madhu
03-22-2016 07:38 AM
hi Madhu -
have you gotten any feedback that uncovers the answer?
many thanks,
Tammy
