08-13-2012 01:45 PM - edited 03-07-2019 08:19 AM
I have a quick question. I have a VSS (pair of 6506 with Sup 720-10G) with a dual connection to each IDFs. On the Core Switch side the there's a papg connection on gi1/2/3 and gi2/2/3. that is connected to the IDF switch gi0/1 and gi0/2. If link (fiber cut for an example) fails gi1/2/3 fails on the core side, will the IDF still remain up using the gi2/2/3 port?
08-13-2012 04:19 PM
Assuming the VSS in your distro/core layer and the IDF is a switch. Ports gi1/2/3 and 2/2/3 should be in portchannel for use of ePAGP. If that is the case, than a link failure will not bring down the etherchannel. This is all if I understand you question correctly.
08-13-2012 04:32 PM
Yes they are all switches. So the etherchannel will remain up and the and connectivity will be stable?
08-13-2012 04:33 PM
That is correct. As long as you have more than one interface in that Etherchannel, you will be fine if one interface fails.
08-13-2012 04:40 PM
Thanks so much for your response!!. I will be shutting down one interface to test. we have to test fiber strands because we are rerouting the path way and want to pretest to make sure all is good before the contractors get started.
