VSS - Question
colmgrier
Does VSS running between dual 6509E switches support ip secondary addressing under SVI's?
interface Vlan1
ip address 134.226.20.3 255.255.255.0
ip standby ip 192.168.20.1
standby ip 192.168.7.1 secondary
standby ip 192.168.7.2 secondary
standby ip 192.168.20.2 secondary
standby ip 192.168.31.1 secondary
standby ip 192.168.31.2 secondary
Colm
Giuseppe Larosa
Hello Colm,
I hope you are well
Why the VSS shouldn't support secondary IP addresses, even if they are not a good practice but just a fix?
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1131059
it is not listed on the known limitations
see VSS best practices
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
Hope to help
Giuseppe
Giuseppe Larosa
Hello Colm,
I hope you are well
see
Hope to help
Giuseppe
Thanks Giuseppe
All sorted now.
