VTP Pruning
james.hughes
Hi - i'm deploying around 30 Vlans with VTP to a new build. I'm going to use a dedicated VLAN & IP to monitor these devices. Obviously there will be no ports assigned to these Vlans, if i enable VTP pruning, will that cause me problems?
Thanks _ JH
Edison Ortiz
No, I've seen that implementation on many networks. It works quite well.
nambi_gct
As soon as you create an SVI, it logically means that there is a member for the vlan.So pruning will not block the traffic in your management vlan.
