VTP Revision No.
goutam_04
Hi, I would like to know, how do i recover the old vlan configuration if vlan configuration change and update with new switch added in the network with low vtp revision no.
12 Replies 12
goutam_04
anyone can suggest me on this type of issues.
So you want to know if you accidentally adds a switch with a higher VTP revision number to an existent network . The new switch overwrites the VLANs on the old switches in the network.
I'm affraid it's already too late. I don't know if there is a method. I'm affraid not but I want to give you tips at least how to prevent:
OR
change the VTP domain name on the new switch and then back
OR
change mode to transparent and then back.
But I suppose you knew this.
But if you have the problem as descibed earlier, I can't help you
it did not happen, i would like to know the process to recover the old vlan configuration, if this type of problem happen.
hello Goutam,
the only suggestion is to save a
show vlan
routinely
from that output you can rebuild the vlan database by reentering commands
if your legitimate VTP servers are new enough to not use the vlan database context also the saved configurations of them can help in rebuilding the original database.
There is no rollback option to a previous revision number as far as I know.
Hope to help
Giuseppe
Thansk a lot, I wanted to know that there is any option to recover the old configuration or not.
thanks...
Hi Goutam,
Yes there is , you will need to do "Config rollback" or "Config replace"
DAK
could you please give me the process to do it...i will be thankfull to you...
Yes ,
You can have this ; http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html.
OR
Do this Switch# configure replace
disk0:myconfig-1 list time 30
DAK
Good stuff.
But will the switches save the archive configuration only when there is any changes? Or the switches do not care and just save the archive files as soon as the timer triggers them?
Cedar
How is it now ?
working fine ?
DAK
thanks
