VTT threshold recommended values
m.arancibia
Hi everybody,
I am seeing this VTT enviroment values (extracted with the command show environment alarm threshold) in 3 7600 differents boxes.
VTT 1 OK: OK
  threshold #1 for VTT 1 OK:
    (sensor value != 0 ) is system minor alarm
VTT 1 outlet temperature: 36C
  threshold #1 for VTT 1 outlet temperature:
    (sensor value >= 100C) is system minor alarm
  threshold #2 for VTT 1 outlet temperature:
    (sensor value >= 115C) is system major alarm
VTT 2 OK: OK
  threshold #1 for VTT 2 OK:
VTT 2 outlet temperature: 35C
  threshold #1 for VTT 2 outlet temperature:
  threshold #2 for VTT 2 outlet temperature:
VTT 3 OK: OK
  threshold #1 for VTT 3 OK:
VTT 3 outlet temperature: 33C
  threshold #1 for VTT 3 outlet temperature:
  threshold #2 for VTT 3 outlet temperature:
I want to confirm if this values are correct, because looks elevated (100C and 115C), or what values are recommended ...if it possible change it.
Rregards.
This is default value which is set already and there is no need change it.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Arumugam Muthaiah
This sensor vlaue is correct and this is maximum allowed temperatures for the sensors which is defined as minor and major alarm
There are two alarm types: major and minor.
  • Major alarms indicate a critical problem that could lead to the system being shut down.
  • Minor alarms are for informational purposes only, giving you notice of a problem that could turn critical if corrective action is not taken
The system sensors set off alarms based on different temperature threshold settings. You can determine the allowed temperatures for the sensors by using the #show environment alarm threshold command
I verified on LAB and found below detail,
switch 1 VTT 1 OK: OK
  threshold #1 for switch 1 VTT 1 OK:
    (sensor value != FALSE ) is system minor alarm
switch 1 VTT 1 outlet temperature: 32C
  threshold #1 for switch 1 VTT 1 outlet temperature:
  threshold #2 for switch 1 VTT 1 outlet temperature:
switch 1 VTT 2 OK: OK
  threshold #1 for switch 1 VTT 2 OK:
switch 1 VTT 2 outlet temperature: 30C
  threshold #1 for switch 1 VTT 2 outlet temperature:
  threshold #2 for switch 1 VTT 2 outlet temperature:
switch 1 VTT 3 OK: OK
  threshold #1 for switch 1 VTT 3 OK:
switch 1 VTT 3 outlet temperature: 33C
  threshold #1 for switch 1 VTT 3 outlet temperature:
  threshold #2 for switch 1 VTT 3 outlet temperature:
When the voltage termination (VTT) module reaches 100C, the System will throw the minor alarm, and when it reaches the 115C, it wil show major alarm
Aru
Hi Aru,
Thanks for your answer, I already had this information but I want to confirm if this values (100C and 115C) are
fixed and is not possible or necessary change it.
Aru
