VXLAN Slowness
mediaos718
I set up VXLAN across 4 Nexus 9k - Most of the VXLAN traffic consists of video camera traffic. We notice that we can not access the cameras via HTTP and HTTPS across the VXLAN - We are able to get pass the loading page but video feed is not loading - Ping is working. We can access the cameras if we do not cross VXLAN.
- We enabled jumbo frame on uplinks of the N9k.
Has anyone else encountered this issue?
Vinit Jain
what is the MTU on your L3 VNI as well as L2VNI?
--Vinit
Please see the MTU values below:
vlan 1119
  name L3-vni-vlan-1
  vn-segment 39100
BK-Core-01# sh int vlan 1119
Vlan1119 is up, line protocol is up, autostate enabled
  Hardware is EtherSVI, address is  006b.f183.c6e7
  Description: L3-vni-1-routing  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  ARP type: ARPA
  Last clearing of "show interface" counters 03:18:16
  L3 in Switched:
    ucast: 0 pkts, 0 bytes
BK-Core-01# sh int nve 1
nve1 is up
admin state is up,  Hardware: NVE
  MTU 9216 bytes
  Encapsulation VXLAN
  Auto-mdix is turned off
  RX
    ucast: 885613072 pkts, 107194231828 bytes - mcast: 60602953 pkts, 56660962806 bytes
  TX
    ucast: 1587294477 pkts, 1795414605166 bytes - mcast: 12393935 pkts, 2698843930 bytes
interface loopback1
  description VTEP/BGP
  no ip redirects
  ip address 10.20.4.20/32
  ip address 10.20.4.21/32 secondary
  ip router eigrp 100
  ip pim sparse-mode
loopback1 is up
admin state is up,
  Hardware: Loopback
  Description: VTEP/BGP
  Internet Address is 10.114.4.20/32
  MTU 1500 bytes, BW 8000000 Kbit, DLY 5000 usec
  Encapsulation LOOPBACK, medium is broadcast
    113558 packets input 7316434 bytes
    0 multicast frames 0 compressed
    0 input errors 0 frame 0 overrun 0 fifo
    0 packets output 0 bytes 0 underruns
    0 output errors 0 collisions 0 fifo
    0 out_carrier_errors
Your L3VNI SVI is configured with default MTU. Could you please set it to 9216.
--Vinit
